RCU Forums - View Single Post - prop nuts and washer source
Old 03-06-2010 | 09:10 PM
Campgems
Default RE: prop nuts and washer source
As long as they are the same thread size, the saito should work on the O.S. The only issue may be the washer as some of the saitos I have, have a metric prop shaft and imperial thread size. Or, look at the equivlant size Magnum for a replacement washer/nut set. The one for the Magnum 52 four stroke is only like $6.95 for the three piece set. 1/4-28 thread size.
You are correct about the washer thickness. It is a much more robust washer than you will ever find at even a well stocked hardware store. The hardware store washers are stamped from sheet. The thick tapered prop washers are machined to shape and size.
Don
