Need more help on my Tiporare
The rudder is made buy gluing two 1/4" sheets of balsa together and sanding the taper in to it.
Ailerons and elevators are cut from the surface and capped with 1/4" balsa then sanded flush with the surface. Be sure to remove 1/4" foam from the surface to allow for the facing you are gluing on.
John
