RE: Bob Cat Copy Falcon 120 Jet
Cody - I tend to think the problem is more electrical related. If you're using just one receiver battery make sure it's fully charged before each flight. Also you might just try a different type of new battery. Something like a 2 cell A123 battery, regulated or unregulated. Also check your failsafe settings and make sure all surfaces , including flaps, go to a neutral setting. The extra load on the servos when the flaps are actuated may be causing a voltage drop that is causing the receiver to lock out for just an instant when the battery isn't fully charged.
Just my thoughts.
Galen
