RCU Forums - View Single Post - voltage regulator ?
Old 03-08-2010 | 12:13 PM
ChuckW's Avatar
ChuckW
Default RE: voltage regulator ?
ORIGINAL: huck1199
I question wether Higher voltage will cause higer amperage (current). Normally higher potential (voltage) requires less current to do the same amount of work (watts). w=I x V.
I couldn't get that principal out of my head either for along time. When it comes to variable loads on the system doing actual work it is absolutely correct. What I wasn't taking into account though was fixed resistance in the various circuits of the receiver, servos and even things like the wiring, connectors and switch. If you apply Ohms law to a 4.8V battery going through a 2 Ohm fixed resistance, you come up with 2.4 Amps. Make that a 6V battery and you end up with 3 amps. (I just made those numbers up because the math was easy)
I run 6V, 2000mAh packs in the majority of my stuff though and it has been plenty.
