RCU Forums - View Single Post - voltage regulator ?
Old 03-08-2010 | 12:14 PM
42etus's Avatar
42etus
Default RE: voltage regulator ?
ORIGINAL: huck1199
I question wether Higher voltage will cause higer amperage (current). Normally higher potential (voltage) requires less current to do the same amount of work (watts). w=I x V.
Huck,
Your formula is correct, but you're using the wrong formula. You should be using I=E/R. Higher voltage will indeed increase the current draw and thus reduce battery life a little.
Paul
