RCU Forums - View Single Post - How much wing incidence are you running?
Old 03-08-2010 | 03:12 PM
David Bathe's Avatar
David Bathe
Default RE: How much wing incidence are you running?
ORIGINAL: cmoulder
[quote
The H-stab will always "find" zero!
That what i believe.
Not to mention what I believe in trying to accurately measure EXACTLY 0.25 instead of 0.5 ... and I guess I've got the same instruments as you guys.
Come on... it's about 0.5deg. or +0.25wing/-0.25 stab. Yeap about 0.5.... or maybe it was 0.42?
Interesting thing about different wing/stab incidences is you're actually effecting/modifying the engines thrust angle, and the wing stab vertical positioning alone the datum line.
Want to increase your engines down thrust? Adjust the wing and stab.
<br type="_moz" />
