I build an airplane similar to the Great Planes Fundango (
http://www3.towerhobbies.com/cgi-bin...?&I=LXVU18&P=7), and my test flights have been unsuccessful.
Flight #1:
Airplane climbed with full elevator. I eased off elev a little and it dove to the ground, I pulled full elev, and it started leveling off, but not enough before impacting the ground.
Flight #2:
I increased the elevator throw. Airplane flew nose up (like 45 deg)and would not climb anymore than 10 feet. Although not holding full elevator any relax in back pressure would cause the plane to descend while still being nose high. Lost control when it went too far away.
I am using the stock motor & propeller from my Multiplex Sky Scooter. These are the stats:
Motor: Permax 400 6V
ESC: Multiplex Multicont X-08 (8 Amp)
3:1 gearbox
8.4 volt 900 mah nicd battery
Airplane:
Wingspan: 40 inches
Wing chord: 6 inches
Stab span: 10 inches
Chord span: 3 inches
Distance from prop plane to fuse end: 30 inches
CG: ~30% of chord = 1.8 inches (I assume it should be 1/4 to 1/3 of chord).
I'm not sure on the weight or type of propeller.
So, are the flight problems caused by?:
1. Balance - tail heavy?
2. Underpowered. (The reviews are pretty good on this motor:
http://www.hobbyking.com/hobbyking/s...dproduct=4708#)
3. Stab is too small?
4. Elevator is too small?
Please let me know what you think. I'm guessing it's tail heavy and underpowered. Would moving the CG to 1/4 chord and buying a more powerful motor/prop combo solve the pitch problems?
Thanks for any help or advice.
Dan
