<span class="Apple-style-span" style="font-family: Geneva, Verdana, sans-serif; font-size: 15px; ">Is this the thread of doom or what?</span><!StartFragment><p class="MsoNormal"><span style="font-size:11.0pt;font-family:Geneva;mso-ansi-language:EN-US">It now spans 6 years in these pages and probably much more than that if Dar counted in all the lead-up to it.<o
></o
></span></p><p class="MsoNormal"><span style="font-size:11.0pt;font-family:Geneva;mso-ansi-language:EN-US"><o
></o
></span></p><p class="MsoNormal"><span style="font-size:11.0pt;font-family:Geneva;mso-ansi-language:EN-US">For what its worth I agree with Dar on his method on extending the useful life, power and reliability of a tapered bore engine that uses a plated liner.<o
></o
></span><font class="Apple-style-span" face="Geneva, Verdana, sans-serif" size="4"><span class="Apple-style-span" style="font-size: 15px;">
</span></font></p><p class="MsoNormal"><span style="font-size:11.0pt;font-family:Geneva;mso-ansi-language:EN-US">I have a good friend here in Oz that has been flying with MVVS engines since the 1970’s, his background is in metallurgy and machining, and when I approached him about how to run in my MVVS his method almost mirrored Dar’s.<o
></o
</span></font></p><p class="MsoNormal"><span style="font-size:11.0pt;font-family:Geneva;mso-ansi-language:EN-US">To sum up, he has always used castor and the only time he varied to synthetic oil it washed the varnish off an old piston/liner assembly and rendered it unusable.<o
></o
</span></font></p><p class="MsoNormal"><span style="font-size:11.0pt;font-family:Geneva;mso-ansi-language:EN-US">And I was advised to run in my unused MVVS at speed, using his words “like you mean it,” otherwise you risk shouldering off the top of the piston. The insurance protection here is the higher percentage of oil used and the type.<o
></o
</span></font></p><p class="MsoNormal"><span style="font-size:11.0pt;font-family:Geneva;mso-ansi-language:EN-US">Castor will not flash off at the temperature that occur in our engines and is still the ultimate oil for our purposes.<o
></o
</span></font></p><p class="MsoNormal"><span style="font-size:11.0pt;font-family:Geneva;mso-ansi-language:EN-US">The kicker is that my MVVS will be run in as a glow engine and then converted to diesel as soon as it has been, so I doubly want that ‘pinch’ at TDC left in place.<o
></o
</span></font></p><p class="MsoNormal"><span style="font-size:11.0pt;font-family:Geneva;mso-ansi-language:EN-US">Now I could choose any method that I wanted to in running it in and after much investigating I choose the one illustrated in post 1.<o
></o
</span></font></p><p class="MsoNormal"><span style="font-size:11.0pt;font-family:Geneva;mso-ansi-language:EN-US">Cheers.</span><span lang="EN-AU"><o
></o
></span></p><!EndFragment>
