RCU Forums - View Single Post - Don Anderson GP Super Aeromaster build from plans
Old 03-08-2010 | 08:48 PM
jwharkinz's Avatar
jwharkinz
Default RE: Don Anderson GP Super Aeromaster build from plans
Now that I have hade some spare time to spend on my project build recently I can show the results for my efforts in the upper wing mounting system.
This is what I have so far, my front cabane will slot into the wire groove then the rear will have a spring tension pin to hold the wing onto the cabane.
I plan to use four small servos in the wings to activate my ailerons. The next step is to mount the upper and lower wing to the fuse and then make the
outer wing struts, as of yet I haven't decided whether I will use aluminum or wood to construct the parts.
ID:	1393963   Click image for larger version
ID:	1393964   Click image for larger version
ID:	1393965   Click image for larger version
ID:	1393966   Click image for larger version
ID:	1393967   Click image for larger version
ID:	1393968   Click image for larger version
ID:	1393969   Click image for larger version
ID:	1393971   Click image for larger version
ID:	1393972   Click image for larger version
ID:	1393973   Click image for larger version
