RE: Servo extension & retract servo
It is the Servo Arm you need to shorten. Are you using just one servo to operate both Retracts? If so, some people use a Servo Wheel. You drill holes in the Servo Wheel for each pushrod. The closer the holes are to the Servo Arm Screw, the less travel.
