RE: Need a good combat plane plan...
yeah, it sounds like your close. alot of guys use the clark Y for the SSC wings. the plane should loop but if you loop it too tight, it will break out. you have to find the smallest loop circle that it will do and not exceed it. also for SSC we are running the .15 but with a 8-3 prop. we are running slightly over 400 sq in on the wing
