RCU Forums - View Single Post - 1/16th HETZER RC Full Function
Old 03-09-2010 | 02:37 PM
Panzerpaul's Avatar
Panzerpaul
Default RE: 1/16th HETZER RC Full Function
These pictures will show you the brass PE parts I elected to make as substitutes. Someone else may not want to go this route, but I enjoy creating parts in brass, although there is a real challenge to soldering. I like the feel and look that comes with metal, but styrene fabrication can also achieve a durable result. Or one could just use the cast resin parts in the first place……its all up to the modeler. Pix 1-3 show the 4 Fenders. Pix 4-5 are of the Muffler. This was challenge as it was so thin, but I was able to bend and solder it around a wood dowel, and then mate the two cylinders. Pix 6 is of the side Schirtzen and Pix 7 is the MG armored plates (also note that I made miniature hinges for the hatches). The Hetzer had a fixed mounted MG that was controlled automatically from inside. Pix 8-10 are of the wood Jack Block and Tool Box. Pix 11-12 are the Gunner’s Scope bracket and one of the extra Track link Retention Brackets (total of 3). Making the Butterfly Nuts was a real challenge….soldering 3 tiny parts together (see final picture set).
ID:	1394624   Click image for larger version
ID:	1394625   Click image for larger version
ID:	1394626   Click image for larger version
ID:	1394627   Click image for larger version
ID:	1394628   Click image for larger version
ID:	1394629   Click image for larger version
ID:	1394630   Click image for larger version
ID:	1394632   Click image for larger version
ID:	1394633   Click image for larger version
ID:	1394634   Click image for larger version
