RE: SEAMASTER
Only complaints about mine......
No front hatch like the real Seamaster had.
The nacelle for the engine pod both front and back were a bit too small for the wood engine mount it was supposed to connect to.
Angles for the elevator push rod is a little steeper than the original.
A big plus I thought......The bottom side from the step all the way forward to the nose is one solid piece of plywood.
I glazed the inside and made a front hatch for the battery.
Was a bit tail heavy, adding a 4 cell 4.8v JR pack in the nose balanced it perfect.
All and all not a bad deal, even though there needs to be some legwork done on the shipping charges, instead of just basing it off of the size of the box.
