RCU Forums - View Single Post - Ignition power from receiver?
Old 03-10-2010 | 10:24 AM
Carpilot
Default RE: Ignition power from receiver?
My Ignition battery eliminator is installed and working, I did have one issue with it though.
The wiring on the output side of the circuit board broke on my 3rd flight, causing an immediate dead stick. I was able to dead stick it in without any damage, WHEW!
The hot melt glue that was used on the wiring connections (I assume for strain relief) was not on the wiring very good, and the brown wire broke off very close to the solder joint on the PCB. I de-soldered the broken wire and re-soldered the wire on and added some 100% silicone on all the wires for a real grip on everything to keep it from breaking off again.
I have 11 more flights on it after that with no other issues.
