RCU Forums - View Single Post - Need advice - considering a JetJoe
Old 03-10-2010 | 02:24 PM
RCISFUN's Avatar
RCISFUN
My Feedback: (44)
Default RE: Need advice - considering a JetJoe
ORIGINAL: webtech
He he, well thank you all for your advice! It seems as though the consensus is clear! I think I'll just get a JetCat. Someone recommended to me a P60. I hope it has enough power to fly the Velox.
A P-60 will fly it however there are limited airframes for the P-60, what are your long range plans, i.e. the next airframe after this, will the P-60 be enough.
You can buy a bit larger and not use the full power for the Velox
A Jet Central Rabbit has 19 Lbs of Thrust, a Jet Cat p-60 is 13 Lbs...both are priced nearly the same, you get a life time warranty with the Jet Central, plus if you should damage due to a crash there is a very good chance it will be repaired, and not told to make a mantle piece out of it....
