RCU Forums - View Single Post - Jet takeoff from grass??
Old 07-17-2003 | 04:26 PM
Marty O
Default Jet takeoff from grass??
Xtech- You should check out the Jet Model Products Hustler at their website. (jetmodelproducts.com
I've seen the model fly off of grass. As a matter of fact I lost a bet to a friend in that the model actually took off in less space ( about 150' ) than it did off of pavement. The landing used up about the same distance.
The landing gear on this plane is strong and will take all the abuse of a rough field, and the engine intake is shielded by the bottom of the plane to avoid FOD damage.
Check it out
Marty O
