If you have the older strut, from Joe I turned my rudder around, re-drilled the strut. pressed back in my bearings in ,OH OH It's not straight,aim's toward the left sponson, You will need to grind back most of the taper. a little of my strut has split along the side. Now what? LOL will take it back out & try another press, maybe some heat Has anyone had to adjust the strut, for prop walk & engine rpms ,like left trim on that rudder to make her run straight Yes/No ?? Look out bearings out of line
PS got my strut straight
one of Joe's new header's
my rigger cradle
