RE: G26 Throttle Plate removal
As TKG said...a Dremel works just fine. The shaft is brass and is pressed over the steel throttle arm. Use a dremel to grind the brass flat to the steel arrm and then pry the arm off...it will be very easy. Any other method only invites trouble!
Murphey
