ORIGINAL: crashcrash
ORIGINAL: 46u
My Cox P40 had a spring starter. You would put the end of the spring over one of the prop blades wind it up and then let go once the spring unwind it would pop off the prop. [X(]
Question when flying a helicopter what is nose in? Is that with the nose pointing towards the grown on about a 45 degree angle?
Nose in is when you the pilot are looking at the nose of your helicopter while it's in a hover or flying twords you.
