RCU Forums - View Single Post - Proctor Mini Anti-Bipe (with mods) Build Thread
Old 03-11-2010 | 07:03 PM
  #115
R/C Lee
Default RE: Proctor Mini Anti-Bipe (with mods) Build Thread
With a little improvement in the weather here, I was able to shoot the olive drab onto the forward fuselage, and the tricolor on the rudder. Installed the wing servos and attached all of the fittings to the upper/lower wings. Now, the next step will be to attach the wings and put the rigging on, which takes some time (I think there are 24 turnbuckles.) The wing fittings for the "inner" cable tie down points are attached to the root ribs on both upper and lower wings. That way, I'll be able to detach an upper/lower set by unscrewing only four screws and disconnecting only one aileron cable. Should make field setup a lot easier than the larger Jenny. Once I get it rigged, I'll include some photos. Lee
