Hawk Sky engine - Attention John ( Nitrostaff1 )
After I finished building my new hawk sky, and testing all the flight surfaces and engine. Ipowered off and readjusted the horn. After I plugged in the battery again. The engine started smoking after a second or two. Afterward when I unplugged the engine two of the connectors from the engine came that was connecting to something? in the fuselage. It looked like it was a cold solder joint from what was on the wire. I can provide what pictures of the cold solder if you would like. How do I go about getting all of this rectified? My order # is<h1 class="ha"><span class="hP" id=":dv">yhst-17210<wbr></wbr>252890263-<wbr></wbr>117746</span></h1>
