RCU Forums - View Single Post - Fail safe units
Old 03-12-2010 | 08:08 AM
CGRetired's Avatar
CGRetired
Default RE: Fail safe units
If it's a Spektrum, just set the sticks where you would want them should your transmitter fail, then bind the receiver. Usually, as I said earlier, that would be minimum throttle with all other sticks neutral or in the center with trims set that took.
If it's a different radio, well, someone else will have to help you.
CGr.
