They lost my order for the Walkera RX2423 receiver I ordered from Hong Kong. So I can give you my order number in a private message and go from there. You can give me the details in a PM about where to send my old receiver back for checkup by a tech.
ORIGINAL: yadac123
ok so if you move the right joystick does the servos move? seems like the speed controller in the 4 in 1 unit is bad. Order number? I can have you send it back for checkup by tech, if it has problems I ill exchange for you.
Andy
ORIGINAL: Eddie48
ORIGINAL: yadac123
ok did you make sure you put the left joystick down and the speed trim down. The ESC can not be initialized when the speed trim is not at the lowest. Did you make sure you check the motor and make sure the motor is working? You can get a piece of wire and connect a AA batteries into the motor and see if it spins.
Andy
Ichecked the motor with a piece of wire and it did spin.
I have the left joystick down and the speed trim down, I have a solid steady red light on the receiver,but left joystick still doesnot work.
oh well...
[img][/img][img][/img][img][/img]
