The bottom pan is done. I would not set in the brass tubes until AFTER you profile and contour the pan. Both of mine ripped out and had to be reset. Just cut holes so you can access the screws. I have filled in the gap of the curled fillets from post #84 w/ 30 min epoxy and micro ballons. I plan on doing the fillets this weekend. Getting close to glassing time.
