RCU Forums - View Single Post - low end power
Old 03-13-2010 | 10:46 AM
rk345345
Default RE: low end power
I'll look into thoes bells. Hopefully the 2 speed is working, or will start working or I'll send the whole thing back to red cat. I've had it out like 3 times, switch does not work , had to replace front servo rite out of the box cause it would only turn one way. I don't want to stick $200 into it to get it to run just fairly well, If I'd a known that I would have just sprung the extra and bought a more expensive one that would run out of the box. You know what I mean ?
It's raining hard here today and sounds like it may tommorrow also, so I mite not get to it. And I'm finally going back to work monday, frost is finally out from under the roads so we can start digging. I'll try to lower the lsn tomorrow if it dries up for a while.
So theres no way to see if it's stuck in second gear other than to listen?
I have never worked on one, but shouldn't the bigger gear be free spinning when not in second? Like rite nowif I turn thefly wheel both black gears turn . I'm confused .
I see this set that looks really nice, metal gears and very high quality looking, threaded cluthbell, man would this be nice. Has any one tried it?
http://www3.towerhobbies.com/cgi-bin...R&I=LXBTB6
