RE: Bob Cat Copy Falcon 120 Jet
Six degrees should be the right amount of down thrust for that engine. First, I suggest that you put the CG at 330 mm. and set your elevator trim for straight and level flight at your normal flying speed. Then adjust the down thrust if needed.
Joe
