ORIGINAL: The_Shark
well its all buttoned up, it took 4 hours to change every mount (front and rear) and replace both diffs (which i had to dissasemble, clean of grease and refill)
so now i replaced
front shock tower,front brace, rear brace, all pins, swaybar, front diff
rear shock tower, rear pins, front brace, rear brace, diff.
what was upraded
front/rear pillow ball suspension
big bore shocks and red springs
clutch bell, alu clutch shoes
jpx engine
jammin jp-2 pipe
htq servos
alu servo mounts
alu chassis braces
radio
what hasent been repaired or replaced? servo tray, servo saver, gass tank,brakes, chassis. everything else is new.
now its pouring out[&o]
Know how ya feel just finished a jammin .5 CRT pro into brushless(gotta paint it still) and was like OK TIME TO TEST look out its raining...
Only got it so I could have something that could handle my brushless system that has caused other RC's a few issues. I didn't like the idea of letting my $100 BL system goto waste so I spent $200 on a truggy that would be able to handle it so I got use out of it
OK I lied it also looked damn cool too I just used that as a reason to justify getting blowin $200 on it along with all the parts needed to convert it
