ORIGINAL: griesel With JR 7202's and Spektrum DX7 ( they have almost identical software ) I can get 3 settings of spoilerons / flaperons with a 3 position switch. How is this done with the Aurora 9?????
I have connected the camber up to the slider switch, but disconnected it due to my accidentally
bumping the switch causing disruptions in flight. So I much prefer a three position switch.
I should have qualifiedthe above post related to trials under Acro, will re-check under Glider mode later today, together with your 3 position switch, and revert if anything different found.
<font color="#22229c"><u>Aurora A9 - Slider </u></font>DIY Centre Detente (Notch) Slider - two notches in the sliderwould assist maintain 3position locations with the slider.
Some very good tips and screen shots at
<font color="#22229c"><u>Aurora A9 - DLG</u></font> Set up guide with many screen shots for setting Camber, P.Mixes, Flap Control etc *
regards
Alan T.
