RCU Forums - View Single Post - Super Tigre ST 3000 Gas Conversion
Old 03-14-2010 | 01:58 AM
nitrometan
Default RE: Super Tigre ST 3000 Gas Conversion
Tnx for reply,I must to tell you that I found the sweet spot on L setting and the idle speed I set with butterfly screw only.Quite smokey,does not seem to be lean.Has same performance as DLE 30.DLE 30 also quits if idle is set under aprox.2000 rpm,all this at good L setting.
YO8SSD
