RE: Bob Cat Copy Falcon 120 Jet
Lowering the turbine idle can result in a low speed compresser stall and flame out, it you need to do that again I suggest you put a mix on with your retract valve to keep the idle at the manufactures settings whilst in the air and having the lower idle only available on landing. Do remember to re-teach your ECU the new settings.
Mike
