RCU Forums - View Single Post - Balsa USA Super Cub Build
Old 03-14-2010 | 06:08 AM
  #413
Tony Hallo
Default RE: Balsa USA Super Cub Build
My memory is 2 degrees down thrust, zero right thrust. The first photo clearly shows the down thrust, the second photo shows right thrust, don't mind the dirty laundry, can't see any right thrust built in. Maybe some successful builders can weight in here, I'm still painting so I can't report if any right thrust is necessary or not. From my experience right thrust is only necessary on grossly overpowered airplanes, I don't expect my build to be overpowered. Posted some photos of the progress.
ID:	1397693   Click image for larger version
