RCU Forums - View Single Post - ESCs Stopping without notice
Old 03-14-2010 | 07:10 AM
stmjxxi
Default RE: ESCs Stopping without notice
Just make sure you are using the 50 amp rating and ensure adequate ventilation.
If you are running in water then you have triggered a safety cutout.Since there is no indication in this,you are left in the dark.Force cooling or reduced battery voltage will confirm if that is the case.
It would also be advisable to measure your current drain which is caused by friction or oversized props.
