RE: Vortex wheels & tires
Hey guys, well I put 2.2 wheels Traxxas part no. TRA3674 and mt old Sledgehammer tires with Team Epic Inc. TRITK1512 foam inserts. Had to use a small washer on the front to space the wheels out a little. Also put a Rustler body on it. With the wheels and tires mounted it is a lot more controlable. No more speed flips now I can run it full throttle without flipping. Tall grass is not a problem either and the chassis dosen't slap the ground when landing from a jump. The body, now I can jump it without the nose going straight up when it gets any air. It jumps level. Well now I need a fan for the ESC. Since I can run longer the thermal shut down does it's job and shuts me down. No biggie the fan will be put on shortly. Stock tires and wheels measure 3 5/8" tall and 1 5/8" wide. The new set up is 4 3/4" tall and 2 1/2" wide. Thanks
