RE: -Official Traxxas JATO Thread-
Running a alum. shock tower in the rear on a jato is a bad idea. The plastic one will flex and break if it gets hit hard, the alum. one will transfer the impact to your tranny case and crack or break that and its much harder to replace. I have a extra plastic tower in my tool box just incase, only one time out of many years have i had to replace it. The weak spots on the jato are as follows, the front plate, the tie rods pull out of front end, the roll hoop on the right side can crack off the top plate, the tranny gears are a bit weak and blow out fast on a well broken in 3.3(especially with bigger tires), brakes are a bit weak, the throttle servo casing is prone to cracking. Those are probably most common issues id work on. Good news is they all have fixes except the tranny gears, only thing i found was the hotracing metal (not alum.) gears.
