RE: MLD-35 Gasoline Engine
...here is request # 2. Rotate Carburetor block
The new REAR CARBURETOR setup required a complete crank case, cylinder design. This fored us to design your MLD-35 to operate at ALL positions. Some of you asked us to rotate the carb block, because they wanted to improve access to the arms. With the new design, you can rotate the engine around its crank shaft to any degrees... In another words with the current design, you are no longer limited to 0 degree or 180 degrees. You can now position the MLD-35 from 0 to 359.9999 degrees!
Peace,
Steven Chao,
CERMARK
