RE: TURBINE CHOICE
I have the rabbit. The spool up is wicked fast. With my hand data terminal plugged in, from the time I start moving the throttle stick (not when it gets to full, but the time I start moving it) to the time the data terminal reads full rpm is usually a bit less then 3 seconds. However I would call it 3 seconds. Once you get off idle to say around 1/4 stick, it's a second if not a bit faster. Fastest spooling turbine I have ever seen.
