ORIGINAL: RC11
Hey Guys,
Got my motor and pipe! Dave Ruminski was helping me set things up on his test stand. Measuring things out to get the 27.5'' from plug to the 1st baffle or 33.5 to the end of the pipe..... Right? So therefore it should be 6.0'' from the 1st baffle to the end of the pipe...Right? That distance is 6.5 on my pipe....Also.. Should I have to add a 2.5'' piece of pipe to an uncut header to achieve the 27.5 inches? Could I have recieved the wrong pipe?
Dimensons of the Pipe are 23'' long (body not including stinger)
7/8'' inlet
2'' od
16.5'' to the 1st baffle
Thanks for the help,
Rick
Rick,
The ES30G pipe is 23" long (X 2" OD ) from inlet to the back (no stinger included). First baffle is 17" from the inlet which definitely means 6" from baffle to end of pipe.
If you are measuring 16.5" I suggest that you email Ed Skorepa and ask him about it. If you need to add another half inch, some pipe tunnels may not accommodate it. I know mine would not. I am maxed out.
Adding 2 1/2" to the header also doesn't sound right. It shouldn't be more than 3/4". Please measure the length of the header from exhaust flange to the end. My header is one for the webra so I can't help but Bob and Ed both have the one intended for the OS so they could measure and report. It could be that the header you got from Tower may have been a modified return
Matt
