well i maiden my giles 202 with dle 30 in its stock form did not miss a beat the only adjustment i made
was the idle ran like clock work what great little donk
Hi buddy there is some things i would change to to get the C/G right one you will need to put all your battery's up front with dle 30
turn the carby up side down
put the motor from the fire wall to the back of the prop 145 mm
and fix the wheel pants not very strong my ones crack in the air on the maiden in the air
http://www.youtube.com/watch?v=JEeF5L6UYVk
