ORIGINAL: mglavin
Rob,
Using the TACH to back off the high speed needle until you note a loss of at least 300rpm. The 1/4 turn is simply a suggestion. And remember when tuning; the low and high speed needle interact to some degree with this carb.
Running the lil beast lean will cause and affect a cough as you noted, throwing the prop/spinner and even taking out the prop hub key....
Michael Glavin
Run any engine with a walbro carb at full throttle, close off the low needle and see what happens! Look out!
I set my gas stuff 100 rpm rich from peak, glow 300 rpm rich.
