RE: Black Magic VF3 Build Thread
Chris and I did the setup last night. It weighs 10lbs9oz and it going to need about 20grams in the nose to get the CG correct. I'm could go with a solid backplate FAI spinner or for that matter I could remove my HS81 micro servo from the throttle and put in standard servo, then remove the lead. We should be able to fly today and I'll give report back when we do.
Larry
