RCU Forums - View Single Post - Starting Problems
Old 03-16-2010 | 12:13 PM
rjsdad
Default RE: Starting Problems
Do this. Make sure that all of the tires are off the ground turn the drivehaft with your fingers. Do the wheels turn? You should be able to feel some reisitance since it has to go through the diff. I want to see if the diffs are good. If so then I would say the problem might be in the transmission.
