RE: Engine Comparison... Help?
in a way, yes.
normally with more torque you will turn a bigger prop for sure.
rpm posted are not the max rpm's.
I don't know what size prop you are looking at turning?
I would say that either the NR .21 or .28 will get that SW 36 going like snot.
and in all fairness I don't think you would be disappointed with the TT .46, in the end it all comes down to your decision.
an engine with the proper crank or an engine with an SG crank that will need you to modify a flywheel or find someone that makes one.
what ever your decision is, I am sure you will gave fun.
Dan.
