Originally posted by rctimm99
Hey... thats my motor! Flip the flywheel around???? pretty slick. Sound like I have a Ryobi 31 cc with some extra metal housing on the front...
Not the same motor. You said yours has a rear mounted carb, mine is side mount. As for the flywheel, that's the way mine was manufactured. They can't be flipped around because they sit on a tapered shaft. However, I DID grind away all the fins for maximum weight savings, and then re-balanced it.
I agree, it sounds like yours is a Ryobi design.
