RCU Forums - View Single Post - Cox piston Failure
Old 03-17-2010 | 01:14 PM
icerinkdad
Default RE: Cox piston Failure
Racing Cox reed valve engines in control line I used to see this happen occasionally. If the ball joint connection is loose enough to feel then every time the engine turns over the end of the pushrod is pounding away at the top of the piston from the inside. A small diameter prop or unloading the engine in a long dive will accelerate the wear causing quick failure sometimes.
The piston reset tool from Cox International is a good investment.
Bob
