Einstein-low readings
The 9 volt battery doesn't have anything to do with your readings. It just keeps power on the electronics in case of a power failure. It just seems that your setting for the minimum cut-off voltage is set low from the factory. Personally I would not worry about it so long as the readings are fairly consistent.
