RE: SYSSA 30CC GAS MADE IN USA
Fly & BB, I use 1/4" dia. x 3/4" long piece of shrink tubing on each screw. I bit of heat and it will conform to the spring under the head of each screw. With the hole in the cowl in the right position, it is realatively easy to adjust the screws even w/ the engine running.
I gave up on the Syssa inignition mount. I felt that it need isolation. Bob
