Is that a technical term???
</p>
I've had several planes with the bolt on tail feathers they are ok as long as you do regular maintenance to ensure the bolts are tight.</p>
However, I have have noticed a problem with the Escapade. The wood in the tail that the bolts mount into is a little bit tender and can be easily "crunched" if you bump the tail feathers. I've had 2 of the Escapades and have seen the same problems. To cure it I strengthened the tail by using epoxy with mill fiberglass in it to make the area stronger. </p>
Ken</p>
