Are you running stock hardware or upgrade parts? Post some pic of your boat including pics of the transom (rear end). Where did you get this prop? Is it a stock prop off the Traxxas boats? 2 fins, do you mean 2 bladed prop or 2 turn fins??
ORIGINAL: hasek1616
im relatively new to the boating world and im going to be running a plastic prop with a diameter of about an inch with 2 fins on a traxxas blast with a velineon system on 6 cells, do you see anything problems i might have, what about trim, the water will be completely flat and its going to be speed runs only, should i have it trimmed up or down or in the middle? (again im new to all this)
