RCU Forums - View Single Post - Weston Magnum R build
Old 03-18-2010 | 07:11 PM
  #67
mk1spitfire's Avatar
mk1spitfire
Default RE: Weston Magnum R build
Good stuff, but when you fly magnum, you may only want full throttle!! A swtich instead!
I try and set up mechanically the best i can,followed by radio, that means getting the right resolution, ie same horn length hole as throttle horn and like you said aim for 50% open on carb.
