ORIGINAL: MetallicaJunkie
overnight it with a wall charger....then use a peak charger on the way to fly if you have one ....tbh i usually peak charge at about 1/5 c the night before go fly on my nhmh batteries...they will usually last me all day sat and sun ...about 6-7 flights or so
talk about overkill, most of the time 4-5 flights will only use 200ish mah, most wall warts charge at around 100 mah, so 4 hours should be more than enough. i would throw it on the charger and once it starts getting warm its done
or just buy one of these
http://hobbycity.com/hobbyking/store...idProduct=7028 when they come back in stock
